OctaneRender™ for Blender 2020.1.XB2 - 21.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Mac OSX and Linux versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgraded to 2.81a
  • Integrated 2020.1 XB2
    • Supported octane sphere light("Property-Light-Sphere")
    • Supported octane quad light("Property-Light-Area-Square/Rectangle")
    • Supported hair material
    • Supported randomwalk medium
    • Implemented sphere attributes("Property-Object Data-Octane properties-Sphere Attributes")
    • Supported OSL LiveDB
  • Enhanced the OpenVDB feature
    • Added missing options(velocity scale, velocity grid type, motion blur...)
    • Supported to customize absorption/scatter/emission/velocity grid id as SA
    • Fixed VDB volume renders as black box(SDF type) issue
FIXES SINCE LAST RELEASE
  • Supported to save cryptomatte passes as 18.x
    • Fixed the brighter image issue when both "alpha channel" and "keep environment" are ticked
    • Supported local view mode for OctaneBlender
    • Disabled alpha in universal material Transmission by default
    • Fixed the crash issue when exporting scene with motion blur
    • Fixed the tile image resolving errors
    • Tried to activate a license when accessing LiveDB
    • Fixed obj import failure
    • Updated the bug report link
You can read about new features of OctaneRender™ 2020.1.XB2 here:
viewtopic.php?f=33&t=73550
1. OctaneRender™ Server
Windows
Blender Octane Edition - 21.1 (2.81)
Octane Server - Enterprise Edition - 21.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 21.1 (2.81) Linux
Octane Server - Enterprise Edition - 21.1 Linux
OSX
DOWNLOAD
Blender Octane Edition - v21.1 (2.81) OSX
Octane Server - Enterprise Edition - v21.1 OSX
linograndiotoy
There's an issue with Area Lights right now. They're basically emitting light from the wrong side. It will be fixed soon.
