Displacement on C4D is causing constant bouts of freezing
Acidicfriend
I am using octane to use and create terrains and I've never had cinema 4d freeze more often. I'm rather frustrated as I have a decent enough set up not to have these issues, an amd ryzen 3900x and an nvidia rtx 2080. But Octane continues to lock up when dealing with simple texture displacement for terrain I'm working on - it's insanely frustrating.
have you installed Standalone (not the zipped version)?
it changes some Windows registry optimized for GPU rendering.
If not enough, please write to [email protected] to better investigate the issue.
ciao Beppe
Acidicfriend
bepeg4d wrote:Hi,
ciao Beppe
Hello, I do not recall which version I installed, could you link me to the standalone so I may check ?
any kind of Standalone installer is good for changing the TdrDelay.
Please visit your personal Downloads area:
https://render.otoy.com/account/download_archive.php
You need to select your purchased version from the Select Software pop up:
ciao Beppe
