OctaneRender 2020 for ArchiCAD [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for ArchiCAD TEST and STABLE releases.
SOLUTIONS TO COMMON ISSUES
1) Make sure your NVIDIA drivers are up to date.
2) How do I extract the ArchiCAD 23 textures from the ArchiCAD 23 Library - 'File'->'Libraries and Objects'->'Extract a Container'. Select C:\Program Files\GRAPHISOFT\ARCHICAD 23\ARCHICAD Library 23\Surface Catalog 23.lcf to extract to Documents\AC23SurfaceCatalog. Then add the library to the Library Manager.
ArchiCAD Version
This version of the plugin runs on ArchiCAD 21, 22 and 23 - 64 bit Windows (Vista, 7, 8 and 10).
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 451 or higher.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using. This version matches OctaneRender Standalone 4.00.
Support Issues
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- ArchiCAD version (ArchiCAD -> Help -> License Information -> Version and Build Number
- OctaneRender for ArchiCAD version (ie. 1.02a)
- In the unlikely event of a crash, pls provide the dump report from the C:\Users\[username]\Graphisoft\BugReporting-[version] folder (on Win 7). Either post or email (to "paul at physicalc-software.com") the "ArchiCAD-XXXXXX-FATAL.RPT" file from this folder.
For more information
- Read the on-line manual
- Read the FAQ
- Watch Tapperworks Showcase Part 1, Part 2 and Part 3
- Watch Tapperworks Render Passes video http://youtu.be/sXnLcWEbbmY
- Watch the Grass Generation video http://vimeo.com/113454418
- Post your question on this forum thread
Download Links
Once you save a .pla/.pln scene with the Octane 2020.1 or Octane 2020.2 versions of the plugin, you will no longer be able to open the OctaneRender plugin with that scene loaded in ArchiCAD with a plugin compiled with an earlier version of Octane.
Current TEST build (Octane 2020.2)
Current STABLE build (Octane 2020.1.5)
Release Notes
2020.2.0.105 (26-Feb-2021)
- Compiled with Octane 2020.2
- Fixed issue where the Global Illumination Mode could not be set on the Direct Lighting Kernel
- Added the following Octane 2020.2 nodes: Null Material, Chaos Texture, Channel Inverter, Channel Merger, Channel Mapper, Channel Picker
- The following Octane 2020.2 features are implemented: Nested Dielectrics,
- The following Octane 2020.2 features are NOT implemented: OCIO, AOV/compositing nodes, Multi-scatter tools, Composite Texture
- FIxed issue where clicking the CSV button would crash ArchiCAD
- The Select Material from Selected Item combobox now works correctly for stairs and other elements with sub-elements
2020.1.5.104 (10-Sep-2020)
- Compiled with Octane 2020.1.5
2020.1.4.104 (25-Jul-2020)
- Compiled with Octane 2020.1.4
- Added support for .DDS image files
- Added support for ArchiCAD 24, and removed support of ArchiCAD 21
2020.1.0.103 (28-Apr-2019)
2020.1.0.102 (17-Apr-2019)
- Compiled with Octane 2020.1 RC3
2020.1.0.101 (21-Mar-2019)
- Compiled with Octane 2020.1 RC2
2020.1.0.100 (06-Mar-2019)
- Compiled with Octane 2020.1 RC1
2020.1.0.99 (22-Jan-2019)
- Compiled with Octane 2020.1 XB3
- Added the option to load .FBX files as proxies
2020.1.0.98 (18-Jan-2019)
- Compiled with Octane 2020.1 XB2
- Fixed Octane Log error when loading LiveDb materials
2020.1.0.97 (17-Dec-2019)
- Compiled with Octane 2020.1 XB1
- Added Kosek-Wilke Daylight Model
- Added the Hair Material node (I doubt this will be of use the ArchiCAD plugin users)
- Added the Random Walk medium (NOTE: If you enable Lock Step Length Pins on any of the Mediums, the Volume Shadow Ray Step Length will override the Volume Step Length)
- Octane 2020.1 Quad and Sphere Lights are not implemented
I have updated the installers at the top of this thread with:
2020.1.0.98
2020.1.0.99
Jasonr
Hello Paul.
Can you check please for the latest version of 2020 XB3,
when I choose a beam element the materials are not shown ot the materials tab. It remains empty so I have to search for the material or use the pickup function.
This is not happening for the rest of archicad elements.
Thank you.
ASUS Z10 PE-D8 WS/2 x XEON E5-2680 V4/64GB RAM/1xQuadro M5000/2x NVIDIA GTX TITAN Pascal/ Windows 10/ Archicad 20
Jasonr wrote:Hello Paul.
Thank you.
I suspect this has always happened. Are you able to check a previous version please? Also, you could try the solution for Curtain Wall objects detailed at https://docs.otoy.com/ArchiCADH/ArchiCA ... ations.htm.
2020.1.0.100
2020.1.0.100
2020.1.0.102
2020.1.0.103
Jasonr
Thank you Paul.
Really fast!
