Bake sunlight system or environment to HDRI
Refracty
As we know it is better to use HDRs then sunlight as long as bidirectional pathtracing is not introduced.
So wouldn't it be possible to bake the environment (sunlight + sky or all incl. geometry) into a HDRI?
abstrax
Refracty wrote:As we know it is better to use HDRs then sunlight as long as bidirectional pathtracing is not introduced.
Nope unfortunately not, because the reason why sunlight is causing problems is its size. If you would like to bake a correct HDRI the sun would be only 1 or 2 pixels wide, which means you would then run into the same trouble as with the daylight system.
Marcus
Refracty
Ah, I see.
Thank you Marcus
