Power in shader properties missing?
BadBilly
Hi all,
I can seem to locate the "Power" slider in the material editor/ shader properties, particularly in Bump, roughness or float layer settings when I load in an image.
Instead, I am getting options for exposure, black point and white point - which appears to do nothing :roll:
Is there something I am missing?
Thanks!
You can use power attribute of ImageTexture
BadBilly
aoktar wrote:You can use power attribute of ImageTexture
Where? Cannot find it anywhere.
mitchino
you are using a bitmap node not an image texture node
BadBilly
mitchino wrote:you are using a bitmap node not an image texture node
Legend - that was the issue. Thanks!
mitchino
De nada.
Only problem with the image texture node is it still doesn't support layered psd files. Maybe one day...
