Hi all,
This is first and QUICK build of the plugin with EXPERIMENTAL 2020.1-XB1 SDK. I'm making this release to offer first RTX BUILD asap for letting test it. Also C4D noises are disabled until 2020.2 SDK.
Do not forget there are some uncompleted features and DO NOT USE for jobs. And OSX builds are not yet available. Any feedbacks are welcome for development and fixing the issues. Enjoy it!
This is the matching Standalone: OctaneRender™ 2020.1 XB1.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also, make sure you use a driver of version 419.xx or higher and if you are working on Mac OS that has a CUDA driver installed that supports at least CUDA 9.1.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Do a clean install while doing this to be sure previous files completely removed.
Changes of 2020.1-XB1-Test2
- Performance improvement: Multi-threading support for material creation on sending a render. Activate it by Settings->Other->Multi-thread for materials
- Missing first clone of multi-instances
- Avoid lags due to unnecessary updates for VDB object under cloners
- Performance fix for vdb object for viewport
- Detection the animation for C4D noises
- Fix: Custom lut strength
WINDOWS ENTERPRISE BUILD (R15-R21)
https://render.otoy.com/customerdownloa ... t2_win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD (R15-R21)
OSX ENTERPRISE BUILD (R15-R21)
OSX SUBSCRIPTION(Studio) BUILD (R15-R21)
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.022). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 435.80) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
-Cuda 9.1 driver for OSX.
ONLINE HELP MANUAL
To use OFFLINE version of manual from plugin
Download following package and extract to Cinema4D/plugins/c4doctane/manual
https://render.otoy.com/plugindownloads ... p-html.zip
V3 SAMPLE SCENES SET(make a request if you need any specific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Cinema 4D Release 20: c4dOctane-r20.xdl64 or c4doctane_R20_demo.xlib
Cinema 4D Release 21: c4dOctane-r21.xdl64 or c4doctane_R21_demo.xlib
Cinema 4D version 2020.1-XB1-Test2 (EXPERIMENTAL) 10.12.2019
I know this is an "alpha" release so to speak but man, you are on point Aoktar! Really want to test drive some of the features so thank you for being so quick with it
Hay Ahmet thanks for putting out this preliminary build.
I have a very simple scene with extruded hexagons inside a cloner (about 50 x 70 clones). The scene renders about the same speed as 2019.1.4 and after about 10 frames C4D crashes.
Rendering out denoise main pass.
Pathtracing
1024 samples
static noise
adaptive sampling @ 512 samples
Group pixels 4x4
System Specs:
Win 10
32gb DDR4 RAM
2TB SSD
3 x RTX 2080 ti @ 42degrees (zero overclock)
1 x 1080 ti (zero overclock)
1600w PSU
5.5gb free GPU VRAM
C4D R21.0.26
Nvidia Studio Driver 441.28
crashlog attached.
Pathtracing
1024 samples
static noise
Group pixels 4x4
System Specs:
Win 10
32gb DDR4 RAM
2TB SSD
1600w PSU
5.5gb free GPU VRAM
C4D R21.0.26
crashlog attached.
- Attachments
- c4doctanelog.txt
- (5.36 KiB) Downloaded 409 times
I just want to throw this out there for anyone that doesn't know ... You can enable RTX by going under Octane Settings -> Devices -> Device Setting -> Use RTX (Experimental)
by handKeeWe wrote:I was literraly entering the thread just to ask that.
Is there some sort of test the RTX boost like in the standalone version or do we have to switch manually?
Let me fix some wrong consideration:nejck wrote:I know this is an "alpha" release so to speak but man, you are on point Aoktar! Really want to test drive some of the features so thank you for being so quick with it
EXPERIMENTAL for core, STABLE for plugin part. Plugin algorithms are not affected by SDK.
Hi Ahmet,
Good job, man
I know this is alpha but i just found this:
There is a shader failure (object renders completely black) when autobump is enabled in VERTEX Displacement.
When normals previewed (info kernel): geometric are fine, shading and smooth are failed.
Just to point this out, in this particular scence, hairs are added to plane, displacement is added to sphere object
It happens when:
- RTX is ON,
- there are hairs in the scene,
Kyehoo
Good job, man
It happens when:
- RTX is ON,
Kyehoo
