OctaneRender™ for Blender 2019.1.4 - 20.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Integrated Blender 2.81
  • New OctaneDB system
  • Implemented a new OctaneDB system. Compared with the old system, the new OctaneDB system
    • support to resolve the materials with dynamic pins(e.g. composite, group layered, displacement mixer)
    • support to resolve the enum value correctly(e.g. "BSDF model", "Metallic reflection model"...)
    • use the Octane texture cache folder which is same as Standalone for Blender OctaneDB
FIXES SINCE LAST RELEASE
  • Removed Old LiveDB System
You can read about new features of OctaneRender™ 2019.1.4 here:
viewtopic.php?f=24&t=73140
1. OctaneRender™ Server
Windows
Blender Octane Edition - 20.6 (2.81)
Octane Server - Enterprise Edition - 20.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 20.6 (2.81) Linux
Octane Server - Enterprise Edition - 20.6 Linux
OSX
DOWNLOAD
Blender Octane Edition - 20.6 (2.81) OSX
Octane Server - Enterprise Edition - 20.6 OSX
