Save EXR render passes crash?
Sub forum for bug reports
Moderator: ChrisHekman
EvolverInteractive
I've tired it many ways but I couldn't get the EXR layers to export without crashing. I had 2 objects in the scene and the resolution of the image was 200x100 (super small). I tried uncompressed, and all the compression. I couldn't get it to export. I also tried different kernels. IDK : I can get discrete passes to export, but that can get messy.
Thanks for your help.
ChrisHekman
Found the issue, should be fixed in the next build.
EvolverInteractive
Thanks sir,
Are you the only developer on this?
I also assume you are doing a big update with Unreal 4.24. Wow, so much work.
Return to “Bug Reports”
