hi there .
this is the first exterior shot of my lake house .
Rico
Lake house exterior
- ribrahomedesign
- ribrahomedesign
thanks radiance ,very much appreciated . new zealand must be beautiful .
Rico
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
- infernoVFX
Hi Rico,
1) The sun angle in your render doesn't match with the sun angle on the backplate
2) When you compositing the image over the backplate make sure that your blacks and whites match, you'll be amazed with the results if you following that basic compositing rule...
Hope this helps,
Voja
Hope this helps,
Voja
Asus rampage III extreme, i7 950 OC 4GHz, Kingston 12GB DDR3, WD VelociRaptor 300gb, 2x WD Black 640gb, Asus ENGTX 580//
Gigabyte P67A UD7 B3, i7 2600K OC 5GHz! Mushkin Blackline 16GB DDR3, OCZ vertex3 SSD, WD black 1TB, MSI GTX 580 lightning OC 993MHz!
- ribrahomedesign
Voja: I am aware of that , i tried with the correct angle and it does not look good ,I like the atmosphere
in the backround ,thats why I use this image . its a minor thing ,and in the end its the house I want to
show in a nice light ,
Rico
Rico
