Hello,
I need some alternatives to the backburner to render several images with Octane.
I'm not able to use the backburner, so if you have any tips or material, where I can find out, please send it to me!
Render Management
- paride4331
Hi samsue,
you could use the 3dsMax batch render tool.
https://knowledge.autodesk.com/support/ ... B-htm.html
Regards
Paride
Regards
Paride
- paride4331
Hi samsue,
yes, Backburner wors. What do you mean by "time limit setting"?
Regards
Paride
Regards
Paride
- paride4331
Hello samsue,
Octane works differently, more efficient then time limit workflow.
try using adaptive sample (set Expected exposure like your camera exposure setting) and Ai Light.
using Denoiser you can reduc max samples; you can make some test, gradually reducing the max samples, before to run your final render.
Regards
Paride
Regards
Paride
