LocalDB material import crashes Maya?
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
itsallgoode9
I'm working in the latest stable plugin and engine and when I try to import a material from the LocalDB it immediately crashes maya. This happened on previous versions too. Is this a common/known issue or just something buggy and a localized issue?
calus
Well last time I checked Local DB was still buggy as hell with the Maya plugin,
it was only usable if you make sure your materials use only old legacy Octane nodes,
because recent nodes support (post V3) was just not implement....
So I'm not sure your issue is the same or a new bug,
I just gave up on this for advanced materials and prefer to use ORBXmaterial, copy pasting nodes from standalone live/local DB...
Pascal ANDRE
itsallgoode9 wrote:I'm working in the latest stable plugin and engine and when I try to import a material from the LocalDB it immediately crashes maya. This happened on previous versions too. Is this a common/known issue or just something buggy and a localized issue?
I can't reproduce it. Could you please attach here the ORBX files of the materials you are trying to import from your LocalDB folder (the ones that crash on your side)?
calus
JimStar wrote: I can't reproduce it. Could you please attach here the ORBX files of the materials you are trying to import from your LocalDB folder (the ones that crash on your side)?
really ? this is very simple to reproduce.
Here any material other than diffuse, specular, glossy crash Maya 2019.2/plugin15.12
and even the legacy materials have errors when they are imported...
defaultUniversalMaterial.orbx
(4.74 KiB) Downloaded 352 times
groupMetallicThinFilm.orbx
(3.34 KiB) Downloaded 346 times
Please implement an option to import any local DB item as an ORBXmaterial (not just for the script nodes)
This would be a quick way to solve the issue for sure without any limitations,crash and errors.
Pascal ANDRE
itsallgoode9
Sorry I haven't got a sample uploaded yet but I see calus chimed in.
I saw an update to the plugin go out, did that fix the issue? I can upload the material if you still need.
I haven't used localDB in years so I didn't know what the status of it is.
calus
itsallgoode9 wrote:I saw an update to the plugin go out, did that fix the issue?
Yes, crash is fixed and some errors are gone but still some issues :
For example Layered Materials and Toon Materials are still not supported ...
Also preparing materials for Maya in Standalone is still way too tedious
as you need to put them in a group with material output before LocalDB, else they are ignored in Maya...(workflow breaker)
Pascal ANDRE
Return to “Bug Reports”
