OctaneRender™ for Blender 2019.1.4 - 20.5 Beta [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to 2019.1.4
  • Support Octane VDB animation(same as 18.x)
  • Add converters for converting Cycles Principled BSDF to Octane Universal Material
  • The converter can be found under "Material-Converters-Convert To Octane Materials"
  • Now only "Cycles Principled BSDF to Octane Universal Material" is supported. More types can be added in the coming versions.
  • Add OSL Delayed UV Projection
  • Add Vertex Displacement Mixer
  • Reorganize kernel as SA layout
  • Support to disconnect visible environment
  • Support to resolve the target node without outputs for octane DB material
FIXES SINCE LAST RELEASE
  • Remove deprecated environment settings structure
  • Hide Eevee/cycles nodes in octane; hide octane nodes in other engines
  • Fix subdivision mesh issue
  • Fix color vertex data error
  • Fix Z-Depth pass crash
  • Fix the export issue for single frame scene
  • Fix the ortho camera wrong positions issue
  • Fix ortho camera render issue with portrait mode under final render
  • Fix the auto-refresh issue for animated image
  • Fix probabilistic render freezing on OSX
  • Fix the int value scope issue
  • Fix Eevee HDRI render issue
  • Fix the ramp setting issue for gradient texture and volume ramp texture
  • Fix some connection issues in the octane node graph
  • Fix render the issue of AO texture in the kernel
  • Rename "Toon Direction" to "Toon Directional"
  • Rename "Matte" to "Shadow catcher" in Diffuse Material
  • Change bump socket from float to shader type
  • Remove Octane prefix
KNOWN ISSUES
  • Materials with dynamic layer configuration(e.g. Group Layers, Composite Materials) are not supported in LiveDB and LocalDB
  • Global mesh type override is not included in the current release
You can read about new features of OctaneRender™ 2019.1.4 here:
viewtopic.php?f=24&t=73140
1. OctaneRender™ Server
Windows
Blender Octane Edition - 20.5 (2.8)
Octane Server - Enterprise Edition - 20.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - 20.5 (2.8) Linux
Octane Server - Enterprise Edition - 20.5 Linux
OSX
DOWNLOAD
Blender Octane Edition - 20.5 (2.8) OSX
Octane Server - Enterprise Edition - 20.5 OSX
