I have a V4 license and tried to run 19.1.2 test release but I wasn't able to. When I tried to run OctaneServer it complained about my license not being a valid All-Access subscription.
Then I ran Blender and it is still 2.79, not 2.80?
Jason
19.1.2 (18.5) Linux problems
C. RAM Capacity (i.e. 6 GB)
To use Octane 2018 and newer you need to upgrade your v4 license.
https://home.otoy.com/render/octane-render/purchase/
System – Windows 11
System – Windows 11
Thanks J.C., but I downloaded the V4 test version that should work with the license I have.
viewtopic.php?f=113&t=73064
Jason
Jason
System – Windows 11
System – Windows 11
Look again at the page I linked to:
[quoteREGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
][/quote]
Jason
][/quote]
Jason
I haven't noticed the links below.
Have you contacted the support? They should answer faster than anybody responsible here.
System – Windows 11
System – Windows 11
From a Facebook post:
That's a mistake. This is 2.79. 2.80 versions are coded as 20.x.
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
No problem.J.C wrote:I haven't noticed the links below.
Jason
Thanks ChrisH, as someone who will never have a facebook account, I wish that they would spend a little more time here.ChrisH wrote:From a Facebook post:That's a mistake. This is 2.79. 2.80 versions are coded as 20.x.
Jason
