OctaneRender™ for Blender 2019.1.2 - 18.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise and Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Update SDK to 2019.1.2
You can read about new features of OctaneRender™ 2019.1.2 here:
viewtopic.php?f=24&t=72891
1. OctaneRender™ Server
Windows
Blender Octane Edition - v18.5 (2.79)
Octane Server - Enterprise Edition - v18.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
OSX
DOWNLOAD
REGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
Windows
Octane Server - Regular Edition - v18.5
Linux
OSX
