[17.10 Blender stops rendering after 22-24 frames
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
In Blender 17.19 (2018) Blender stops rendering after 22-24 frames. Denoiser is turned on. If the denoiser is turned off it renders fine.
This happens only on Windows systems. On OSX it renders fine.
Sample file is below.
denoiser bug.blend
(782.21 KiB) Downloaded 186 times
System – Windows 11
J.C
Here is the log sample:
CUDA error 2 on device 0: out of memory
  -> failed to pin memory
denoiserThread0: Denoiser thread could not able to find the pinned memory of the result buffer. Restart required
CUDA error 2 on device 1: out of memory
denoiserThread1: Denoiser thread could not able to find the pinned memory of the result buffer. Restart required
System – Windows 11
DrawFun
Hello J.C,
It looks like an engine issue complaining about insufficient GPU memory. I will double-check it on my end.
DrawFun
J.C
Hello DrawFun,
I've checked on Standalone and it's the same. Looks like it's engine issue.
System – Windows 11
Return to “Bug Reports”
