Octane does not write F9 renders
mboumans
Previously, Octane for Lightwave was able to write both F10 and F9 renders. Now, only the F10 render works. Using 2019.1.2.
mboumans
Now it does not render F10 renders either.
juanjgon
Hmm, there is an option in the plugin options panel "Disable pass files saving in render frame (F9) mode" to configure if the plugin must save the images while rendering with F9, but F10 should always export them. You should check the output path, write permissions and so on.
Return to “Lightwave 3D”
