camera sequence in 4.23 not work
Sub forum for bug reports
Moderator: ChrisHekman
shenmi
When i animated camera in sequencer,octane do not render at the moved camera position(not moved).
I tested it in unreal 4.23 under new level.
So I can only render one shot.
ChrisHekman
Does your active rendertarget use the "Viewport" camera mode? Or does it use selected camera?
shenmi
yes.I tried everything and it doesn't work.
EvolverInteractive
I just had the same issue, easy fix.
1. Copy the render target
2. Delete it.
3. Paste it back
4. Save and Restart Unreal
4. Have the view port select and the camera locked to viewport
ChrisHekman
Do you know what steps you need to do to reproduce this bug?
EvolverInteractive
No, I haven't nailed down how it happens. I'm switching over my team to Unreal starting tomorrow. I have a breakdown of setting up to render video. I'll have more sample points. But for me I started and finished a project in the same day without updating or adding anything new. It just fought me to render video. I have 2 more projects to do in the next few days. I'll find out then. I need it fixed too.
Return to “Bug Reports”
