Render Error
atraxmade
Hi
My render stops randomly at the same frame and gives me an error?
Specs:
Windows 10
i7-7700K
GTX 1080 Ti
32 RAM
Cinema 4D R20
I'm running latest version of Octane
Thanks in advance! I've attached Render settings and log file.
log_NR_001_i2.xml
(2.63 KiB) Downloaded 171 times
please, open the scene, then go to c4doctane Settings/Others tab, and, at the bottom of the panel, enable all the Log option checkboxes:
Then, load the scene in Live View, then in Picture Viewer until crash, and share the c4doctanelog.txt file that you find in c4doctane directory, or in the path specified in Settings/Others panel, thanks.
ciao Beppe
Could you explain what happen? Crash or stop? Happen on same frame or random? On a specific scene?
atraxmade
I've attached the new log file!
It runs fine till the 50- 60 frame mark and then the render just stops. And cinema gives me an error saying the error is unknown.
octane 2019.1.1 191017 134958.log
(13.96 KiB) Downloaded 160 times
Please, post the c4doctanelog.txt of that rendering session, thanks.
ciao Beppe
atraxmade
Ah I see I uploaded the wrong one, my bad! Also attached is what the render queue gives me when the error happens.
c4doctanelog.txt
(340.53 KiB) Downloaded 241 times
