Hi everyone,
Octane is really new to me so I would like someone to tell the whole process of putting Revit and 3dsMax files into Octane in order to render? Thanks
Revit to Octane
Although I am not a Revit User, I think the best pipeline involves using 3ds max/viz in between,
and linking it as a DWG in 3ds max, then using the octane plugin for 3ds max to render.
Radiance
Radiance
- Jaberwocky
As you will not have access to the full version with the obj. exporters try this instead.crniUBICA wrote:Hi everyone,
1) Export the file from Revit to 3Ds Max.
2) Apply uvw mapping co-ordinates to the model in 3ds max and also assign your various materials to the model in Max.
3) Export as a .obj file.
4) Open Octane.Right click in the node work area and select a new mesh node. That will open a file open box. Then find and select the .obj file that you exported from max and load it into Octane.
Hope that works for you
Regards
Jabba
