I have been having this issue that's been driving me crazy two days now: When I render in IPR to check my materials and such, everything seems fine as should be. When I render to disk though, everything is messed up, completely different scales on the instances, and on the most part just black and white sprites (I suspect it has something to do with alpha though).
I tried everything, from new rops, shops, materials, latest octane build, everything. I am at a complete and utter loss as to why this is happening! Funny thing is that a week ago the scene rendered fine - only thing changed between then and now, is the particle simulation and nothing on the visual side!
Attached are both what I see in IPR and what I get with the same ROPnet:
PS: the scene only renders without a crash every 3-6 frames if I have rendering scene setting set to "Full Scene Reload". Otherwise, it outputs only blank frames, and crashes. (btw, I have the scene in cache to eliminate bottlenecks with the solvers and stuff)
*oh, and by the way, the exact same result happens when I just save the image from the IPR directly
If anyone can share any ideas as to why is this happening on the particular scene, please, feel free to share!
Thank you for your time,
G.
