OctaneRender 2019 for Nuke [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Nuke - TEST and STABLE releases.
Nuke Version
This version requires Nuke 10.5, 11.3 and 12.0 (incl NukeX and Nuke Studio) on Window Vista, 7 or 8, Linux or OSX - 64bit. OctaneRender for Nuke is NOT supported on Nuke Non-Commercial.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Network Rendering
For Network Rendering, you must use the Octane slave release from the Octane Standalone installer which matches the exact Octane version of the plugin you are using.
If you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Nuke version and SR number
- OctaneRender for Nuke version (ie. 2.0.10.16)
- List what other plugins you have installed for Nuke
- The most important part of resolving a problem is me being able to re-produce that problem. So pls provide as much detail as possible in order for me to do this, and if the problem is specific to the scene, send me the scene.
Known Issues
- The "Authenticating Octane" dialog is blank on the Linux version.
For more information...
- Read the on-line manual
- Watch the "Getting Started" video https://vimeo.com/124301518
- Read the FAQ
- Read the Troubleshooting guide
- Integration with HDR Light Studio https://youtu.be/KtawjXhsxy4
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Current STABLE build (Octane 2019.1.4)
Previous STABLE build (Octane 2019.1.1)
Release Notes
2019.1.4.38 (14-Nov-2019)
- Compiled with Octane 2019.1.4
2019.1.1.38 (03-Oct-2019)
- Compiled with Octane 2019.1.1
- Added 5 new Material Layer nodes from Octane 2019.1
- Added the Vertex Displacement node from Octane 2019.1
- Added Composite, Layered and Shadow Catcher material nodes from Octane 2019.1
- Added the Round Edges node from Octane 2019.1
- Added Layer pins to the Diffuse, Glossy, Specular, Metallic and Universal material nodes
- Added Up-Sampler pins to the Imager node
I have updated the installers at the top of this thread with:
2019.1.4.38
