OctaneRender™ for Blender 2019.1.1 - 20.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Updated to 2019.1.1
  • Supported Hair
  • Supported Octane Render Layer
    • You can use the Octane render layer system as you did in OctaneBlender with Blender 2.79(e.g. 17.x and 18.x)(The setting are under "Property-View Layer" panel)
    • Now OctaneBlender can recognize the Collections correctly - which is introduced in Blender 2.8
FIXES SINCE LAST RELEASE
  • Fixed the collection instance crash
  • Added "Custom Properties" in the material panel
  • Removed extra thin layer socket
KNOWN ISSUES
  • Toon material preview may crash due to the issue in SDK 2019.1.1
You can read about new features of OctaneRender™ 2019.1.1 here:
viewtopic.php?f=24&t=72734
1. OctaneRender™ Server
Windows
Blender Octane Edition - 20.3 (2.80)
Octane Server - Enterprise Edition - 20.3
OSX
Installation:
- Just run the auto-installer file.
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Linux
Installation:
- Just run the installer file.
DOWNLOAD
