[20.2 / 2019.1] Orthographic camera not matching
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
ChrisH
In the latest 2.8x build (downloaded 25/9)* I found that the view with an orthographic is different between the viewport and render (when the render dimension is in "portrait").
(The plane is 10x10 BU and the Orthographic scale is set to 10)
It looks like in the render the orthographic scale is always applied to the X-axis, but in Blender/rendered viewport the orthographic scale is applied to the longest axis (Y in the case of a vertical/portrait dimensions**)
(Also note that the Orthographic camera is still "backwards")
(*Could've existed before, didn't do any "portrait" renders earlier)
(**like 1080x1920)
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
DrawFun
Hello ChrisH,
Thanks for your report. Both the Ortho camera issues will be fixed in the coming version.
DrawFun
Return to “Bug Reports”
