OctaneRender™ for Blender 2018.1.3 - 17.10 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Enterprise License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
FIXES SINCE LAST RELEASE
  • Refactor object layer data: now they are moved from mesh data panel to object data panel
  • Fixes in baking layer settings
    • Complete the baking layer transform setting under "Property-Object-Baking Layer", which will be the correct place for changing baking transform
    • Remove the baking layer setting under "Property-Render Layer-Baking Layer"
    • Use "Property-Camera-Baking-Baking group ID" to change the baking group in the scenes
  • Fixes in kernel settings
    • Fix wrong gray UI
    • Hide unnecessary options in different kernels
    • Remove deprecated G.I. modes
  • Fixes in VDB render
    • Fix VDB black box issue
    • Fix VDB update issue under preview render
  • Fix OSL update issue under preview render
  • Fix particle motion blur issue
  • Fix global mesh smooth issue
  • Disable octane export passes unless cryptomatte is on
  • Make it more robust when handling local db path
  • Fix warning about "use_adaptive_subdivision"
You can read about new features of OctaneRender™ 2018.1.3 here:
viewtopic.php?f=24&t=71703
1. OctaneRender™ Server
Windows
Blender Octane Edition - 17.10 (2.79)
Octane Server - 17.10
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v17.10 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v17.10 OSX ZIP
