OctaneRender™ for Blender 2019.1 - 18.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Update SDK to 2019.1
FIXES SINCE LAST RELEASE
  • Fixes in baking layer settings
    • Complete the baking layer transform setting under "Property-Object-Baking Layer", which will be the correct place for changing baking transform
    • Remove the baking layer setting under "Property-Render Layer-Baking Layer"
    • Use "Property-Camera-Baking-Baking group ID" to change the baking group in the scenes
  • Fixes in kernel settings
    • Fix wrong gray ui
    • Hide unnecessary options in different kernels
    • Remove deprecated gi modes
  • Fixes in VDB render
    • Fix VDB black box issue
    • Fix VDB update issue under preview render
  • Fix OSL update issue under preview render
  • Fix group layer material LiveDB crash issue
  • Fix warning about "use_adaptive_subdivision"
You can read about new features of OctaneRender™ 2019.1 here:
viewtopic.php?f=24&t=72584
1. OctaneRender™ Server
Windows
Blender Octane Edition - 18.4 (2.79)
Octane Server - Enterprise Edition - 18.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - Enterprise Edition - v18.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - Enterprise Edition - v18.4 OSX ZIP
REGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
Windows
Octane Server (Regular Version)
Linux
Blender Octane - Regular Version - v18.4 Linux
OSX
Blender Octane - Regular Version - v18.4 OSX ZIP
