Python API for Universal Material 'Metallic'
blastframe
Hi Ahmed,
I'm having a little trouble scripting the creation of a Universal Material and was hoping you could help me.
In Diffuse, Specular, Normal, Roughness, etc. I'm able to insert a bitmap shader because there is a slot for Texture. In the case of Metallic (Specular Map), there is a float next to a button labeled 'Tex.' I can call the button click with:
c4d.CallButton(mat(), c4d.OCT_MAT_ADD_SPECULAR_MAP_BTN)
However, that gives me a contextual menu with the options (Float, Image, Rgb, Gaussian Spectrum). It does not print to Cinema 4D's Script Log, so I don't know the slot's ID/parameters I'd need to insert an ImageTexture.
With this code I can add a bitmap shader for the Specular Map, but it doesn't have an ImageTexture to connect as you can see in the Node Editor image.
import c4d
ID_OCTANE_BITMAP = 1029508
ID_OCTANE_SPECULAR_MAP = 1029508
def addMetallicTexture(id,mat):
    imageTexture = c4d.BaseShader(ID_OCTANE_BITMAP)
    imageTexture[c4d.IMAGETEXTURE_FILE] = "Clear_Plastic_Mat_metallic.png"
    mat[id] = imageTexture
    doc.AddUndo(c4d.UNDOTYPE_CHANGE, mat)
    mat.InsertShader(imageTexture)
    mat.Message(c4d.MSG_UPDATE)
    c4d.EventAdd()
def main():
    doc = c4d.documents.GetActiveDocument()
    doc.StartUndo()
    mat = doc.GetActiveMaterial()
    addMetallicTexture(ID_OCTANE_SPECULAR_MAP,mat)
    doc.EndUndo()
if __name__=='__main__':
    main()
Could you tell me how I can insert an ImageTexture node into the Universal Material's Metallic/Specular Map slot please? Thank you!
You can see every IDs by dropping to script manager. See picture
blastframe
aoktar wrote:You can see every IDs by dropping to script manager. See picture
Hi Ahmed, thank you for the reply. I do know about this and how to get the ID for the ImageTexture node.
I found what I needed in the code for the C++ file: res\description\OctaneMaterial.res:
GROUP ID_MATERIAL_SPECULAR_MAP_GROUP
        COLUMNS 1;
        GROUP ID_MATERIAL_SPECULAR_MAP_FLOAT_GROUP
            COLUMNS 2;
            REAL OCT_MAT_SPECULAR_MAP_FLOAT { SCALE_H; MIN 0.0; STEP 0.01; MAX 1.0; MAXSLIDER 1.0;  CUSTOMGUI OCTNSLIDER;; }
            BUTTON OCT_MAT_ADD_SPECULAR_MAP_BTN   { ANIM OFF; }
        SHADERLINK OCT_MAT_SPECULAR_MAP_LINK { OPEN; INPORT;}
I didn't know the Shader Link was there as it isn't visible. I was able to get it working by using OCT_MAT_SPECULAR_MAP_LINK:
mat[c4d.OCT_MAT_SPECULAR_MAP_LINK ] = imageTexture
Thank you.
Here's working code
import c4d
from c4d import gui
#Welcome to the world of Python
ID_OCTANE_DIFFUSE_MATERIAL = 1029501
ID_OCTANE_IMAGE_TEXTURE = 1029508
def main():
    doc.StartUndo()
    shd = c4d.BaseShader(ID_OCTANE_IMAGE_TEXTURE)
    mat.InsertShader(shd)
    mat[c4d.OCT_MAT_SPECULAR_MAP_LINK] = shd
    shd[c4d.IMAGETEXTURE_FILE] = "texture.jpg"
    shd[c4d.IMAGETEXTURE_MODE] = 0
    shd[c4d.IMAGETEXTURE_GAMMA] = 2.2
    shd[c4d.IMAGETEX_BORDER_MODE] = 0
    doc.InsertMaterial(mat)
    doc.EndUndo()
    c4d.EventAdd()
    main()
blastframe
aoktar wrote:Here's working code
Thank you very much, Ahmed!!!
