Separate Max. sample number per render layer
Hi, It would be cool If we had separate Max. sample number for each render layer. Current layer system work great and adding such option would speed rendering up as some layers don't need as much samples as other do.
System – Windows 11
System – Windows 11
- linograndiotoy
Basically you want to be able to specify the Max sample for each layer and override the ones in the Kernel. Let's see if that's something possible.J.C wrote:Hi, It would be cool If we had separate Max. sample number for each render layer. Current layer system work great and adding such option would speed rendering up as some layers don't need as much samples as other do.
