OctaneRender for Maya 2018.1.3-14.39 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016.5, 2017, 2018 and 2019 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2018.1.3
Changes since version 14.38:
  • Workaround for the issue with Adobe AE scripts.
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
alexito
hi Jim,
using Octane for Maya 2018.1.3-14.39 and all good except that denoiser doesn't seem to work when batch rendering the scene , any current issues bugs ?
I have a 2 x GTX1070 Driver Version 417.71
Thanks a lot.
Alex.
BK
alexito wrote:hi Jim,
Thanks a lot.
Alex.
Hi Alexito,
Thank you for the post.
Would you please share the scene or any error message?
cheers
Kind Regards
bk3d
artdanylov
yeah batch render dont work.
maya 2019
right after I press batch render btn it shows:
// Rendering with OctaneRender... //
// Rendering Completed. See mayaRenderLog.txt for information. //
mayaRenderLog.txt shows only date:
9/2/2019
Scene doesn't matter.
3dsmax 2017, Maya 2017, Windows 10, 32 GB RAM
3x GTX 1080, driver 372.70
artdanylov
also seems like there is instances problem when I`m sending scene from maya to standalone.
While stills renders in maya, deadline can batch render scene(because maya batch render not working), when I export to standalone it eats more then 8gb of vram.
alexito
Hi BK,
unfortunately I cant share the scene , but the same thing happens even with the demo Cantina scene from the youtube Otoy Maya Learning channel, is easy to reproduce.
Thanks.
Alex
Thanks a lot.
Alex.
Hi Alexito,
cheers
BK
alexito wrote:Hi BK,
Thanks.
Alex
Thanks a lot.
Alex.
Hi Alexito,
cheers
Thank you Alex,
We are still unable to replicate the issue. Would you please try Batch render with the attached file?
And if still does not work please copy all the Render settings from your project Maya file to our Maya file and reupload or PM me.
BatchTest.zip
(10.27 KiB) Downloaded 322 times
Cheers
Kind Regards
bk3d
Maskeline
Hello.
Deep files in exr don't work.
When you open the exr files in nuke, you get an error... "DeepRead1:filename: no deep data found in file"
I upload a test scene
Maskeline
I can't upload the file... But it happens to me with all the scenes
Maskeline
Unfortunately this is not a plugin's issue, it can't be fixed on the plugin level. I've just discussed it with the engine team - they are already aware of this issue: this is some rendering engine bug that hopefully becomes fixed in next Octane SDK versions...
Locked
