It would be great to have date & time stamps or delta on each render progress line in the logs. Is this possible?
Eg I just had an overnight high-res still image render take 9 hours and still be incomplete in the morning. It was on 9997/10000 samples, but there was no Cuda activity on the cards. If there were time stamps I would have a lot more info for troubleshooting, including useful info like feedback on how long it would have taken to finish if it hadn't stalled, confirmation that it did stall and when it did so, which could inform strategies in time-critical situations. I'm sure there are other use cases.
Render Progress time stamps?
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
You can activate render log outputs. Settings/others/render log
Ah, OK I see... I have to look in the text file, not the console window. I assumed it would be the same info. thx.aoktar wrote:You can activate render log outputs. Settings/others/render log
