Random Color + Effector Field = blinking Instance color
Sub forum for help and tutorials.
desire
Hello! Need help :(
Can't figure it out how to use Random Color node to get FIXED and NOT blinking color variety while animating clones with Effector Fields.
(Cloner object or OctaneScatter object instancies driven with Any c4d effector+field)
No parameter in Octane material is animated, but using Effector that has moving/changing Fields, gives a blinking random color to a cloners.
Disabling the Fields gives fixed colors under Random Color node, but without needed animating of clones ))
Please help, who knows the right settings for that trivial task?
Thank you in advance
Octane 2018-2019 no matter, Cinema 4D R20.059
the scene is attached
blinking random.zip
(9.2 MiB) Downloaded 348 times
Random colour's result highly depended to clone ids. Just estimating before checking but it will blink if clone counts are changing. Don't use it and Use InstanceColor texture
desire
aoktar wrote:Random colour's result highly depended to clone ids. Just estimating before checking but it will blink if clone counts are changing. Don't use it and Use InstanceColor texture
Thank you for your answer.
I understand what you mean. Haven't got a nice result with InstanceColor node yet, but will give more time for it.
By the way. Have done some tests yesterday and get strange results - some clones flickering, some not. But all of them driven by Effector+Field.
I'll put here an example a bit later.
Return to “Help / Tutorials”
