Kernel Alpha Error
hgarrou
When I enable alpha in Octane Kernel
I get the error in the withAlpha image attached
Disable alpha in the Kernel or disallow partial alpha in the imager and I get noAlpha example.
see attached
Specifically, it appears to be allowing the alpha to "Leak" through Single pollies that have no back sides.
Any Ideas if this is a bug or not?
(2019.1 RC3, 2080Ti, and GTX1080 Windows 10 Pro, 32 GB Ram )
BK
hgarrou wrote:When I enable alpha in Octane Kernel
see attached
Hi Hgarrou,
Thank you for the post.
Octane Viewport render feature is implemented for quick preview[Faster response].
Please use Maya Render view if the Octane Alpha channel is enabled.
Cheers
Kind Regards
bk3d
hgarrou
Thanks so much. I only recently started using Octane in the panels. Thanks a million!
Return to “Autodesk Maya”
