OctaneRender™ for Blender 2019.1.RC3 - 18.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for OctaneRender Enterprise License Holders.
OctaneRender Studio subscribers can access their software by clicking here.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Update SDK to 2019.1.RC3
You can read about new features of OctaneRender™ 2019.1.RC3 here:
viewtopic.php?f=33&t=72219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 18.3 (2.79)
Octane Server Enterprise Edition - 18.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane - Enterprise Edition - v18.3 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane - Enterprise Edition - v18.3 OSX ZIP
REGULAR LICENSES (FOR V4 USERS):
The download links, provided in this post, are intended for OctaneRender Enterprise License Holders (which requires OctaneRender All-Access). For users still using OctaneRender 4, it is possible to access this Test Release thanks to our specially-made "Regular" versions. The links for these "Regular" builds can also be found in the links below:
Windows
Octane Server (Regular Version)
Linux
Blender Octane - Regular Version - v18.3 Linux
OSX
Blender Octane - Regular Version - v18.3 OSX ZIP
