Hello,
i`ve got a problem with a label that I projected on a plane surface. I have realized that the layer with the logo in the object behind the logo layer creates transparency. Depending on the angle from which I look at it, I can almost see in the case where it is dark, of course, and I first thought that the transparency of the logo does not work. What I have to do to make it correctly shown in every angle?
Best regards
Label Opacity
Label transparency is a common point of render confusion, but you'll probably get a better response by sharing a simplified example scene file, or at least a few sample renders that illustrate the problem.
