Getting Alpha from 32bit map
Pavlov
translating some billboards from Lw to Octane.
In Lw i can get Color and alpha info from same node:
In Octane i did not find a way so i had to do this:
same image nodes, one in color and one in Alpha mode.
Am i missing something or this is correct workflow for Octane ?
In case, it would be useful to be able to get Alpha from same node as in LW. Maybe inside Diffuse node there could be an option (like also Vray does) - a switch which tells the node to gather Alpha (and not RGB) for given channels (i.e. Opacity). So if i plug same node into Opacity, it will not get the RGB info but Alpha one automatically.
Paolo
I7 960 3.2 GHZ - 6GB ram - GTS 250 display only - Asus GTX 470
juanjgon
Yes, sorry, currently in Octane the node to get the alpha is not the same than the node used to get the RGB, so you need two nodes even if the image is a single RGBA one.
Pavlov
thanks Juanjo :)
Return to “Lightwave 3D”
