OctaneRender™ for Blender 2019.1.XB2 - 18.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Refactor object layer data: now they are moved from mesh data panel to object data panel
  • Update sdk to 2019.1.XB2
  • New 2019 features(except the built-in script nodes(mix displacement, universal camera...))
  • Add AI Up-Sampler
  • Add "affect roughness" option in kernels
  • Add "max subdivision level" option in kernels
  • Add round edges
  • Add shadow catcher material, layered material, and composite material
  • Add group layer, diffuse layer, metallic layer, sheen layer, and specular layer
  • Add vertex displacement
  • Add "Cutoff" option in postprocess
FIXES SINCE LAST RELEASE
  • Fix particle motion blur issue
  • Fix global mesh smooth issue
  • Disable octane export passes unless cryptomatte is on
  • Make it more robust when handling local db path
You can read about new features of OctaneRender™ 2019.1.XB2 here:
viewtopic.php?f=33&t=71538
1. OctaneRender™ Server
Windows
Blender Octane Edition - 18.0 (2.79)
Octane Server - 18.0
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v18.0 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v18.0 OSX ZIP
