I have created a growing stalk and leaves with Mospline and deformers.
I have made instances of the original plant/stalk and had to set them to Render Instance to avoid funky things going on with the objects (probably because of deformers using world space or something).
Instances are placed, rotated and scaled to fit the scene - all good untill now.
But when I render, Octane runs the first pass, but then stops rendering. I am sure its the plants that are stopping the render since I can do render regions on other parts of the image and when I get to the plants it just runs the first pass.
Any ideas - or has anyone had similar problems???
Thanks for any input you might have.
Octane 4.02.1-R3
MoSpline + instance not rendering
difficult to say.
Please, firstly upgrade to 4.04-R2:
viewtopic.php?f=85&t=71355
then open the scene, go to c4doctane Settings/Others tab, and at the bottom of the panel, enable all the Log option checkboxes:
Finally, load the scene in Live View, then in Picture Viewer, and share the c4doctanelog.txt file that you find in c4doctane directory, or in the path specified in Settings/Others panel, thanks.
ciao Beppe
difficult to say.
ciao Beppe
Thanks for the input!
I have updated and tried rendering again with similar results.
I have attached log, but I cant translate it to anything understandable in regards to any error :-/
- Attachments
- c4doctanelog.txt
- (262.65 KiB) Downloaded 195 times
