OctaneRender for Maya 4.05-13.46 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 4
Maya® Version Requirements
This release will work with Maya® Versions 2016, 2016.5, 2017 and 2018 64-bit on Windows, Linux and OSX operating systems.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
  1. Go to https://home.otoy.com/render/octane-render/purchase/
  2. Select "Upgrade" in the top menu.
  3. Click on "UPGRADE NOW" next to "Upgrade existing licenses to OctaneRender 4".
  4. Select the licenses you want to upgrade and confirm.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Octane for Maya masterclass:
https://www.youtube.com/watch?v=fANBzifhSow&list=PLTqdDmFtprFkzaBM7cmp8ZipQCNupDD0H
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 4.05
Please read the new features implemented from Octane Standalone 4 version our blog post.
Changes since version 13.45:
  • Integrated the 4.05 rendering engine.
  • Fixed the bug: max. samples override did not work from command line in batch mode.
Windows DOWNLOAD
OctaneRender for Maya 4.05-13.46 Demo
Linux DOWNLOAD
MacOS DOWNLOAD
Subscription Studio Downloads
OctaneRender for Maya Studio 4.05-13.46 [Windows]
OctaneRender for Maya Studio 4.05-13.46 [Linux]
OctaneRender for Maya Studio 4.05-13.46 [MacOS]
Jolbertoquini
Hi Jim,
Thanks for the quick publish we did test yesterday and so far so good will let you guys know any issue.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Jolbertoquini
Hi Jim,
we have a issue insidde the plug while we are rendering on the farm images sequences with timewrap and without timewrap
we have this scene with "frames to pre-cache" set at 0, just to inform we use deadline and Command line mode aswell bacth render has the problem.
The problem is when Maya uses the expression to drive this texture sequences in some cases in random machines we get offset like the frame for
example 100 is loading at 100 and at 101 we have something like frame 200 load.
we use this expressions:
the default from the plug :
octaneImageTexture1.frameExtension=frame
And when we have timewrap this one :
octaneImageTexture1.frameExtension=time1.unwarpedTime
This happen with any scene with the imager on one scene set on deadline on multiple machines to render different parts of the animation.
Of corse Standalone doesn't have this problems. must be something with maya I think "frames to pre-cache" maybe when the scene is load in some cases doesn't have
time to run the expression for the rendering maybe... Not sure the reason behid
We did a work around export Orbx files and render on standalon but scenes are heavy and this take a lot process on the workflow.
Or this way which the best one we use Proxy orbx to load the sequence imager and apply this shader on the meshes inside maya works well as a rack for last minute but would be great
to take a look please
Best,
JO
Kuzbasscot
Found a problem, if you use several reference models with UDIM, then when you open the saved scene, the textures are not loaded
BK
Kuzbasscot wrote:Found a problem, if you use several reference models with UDIM, then when you open the saved scene, the textures are not loaded
Hi Kuzbasscot,
We are unable to replicate this issue.
Could you please share a sample scene through PM if there is any copyrighted material?
cheers
Kind Regards
bk3d
Jolbertoquini
Jolbertoquini wrote:Hi Jim,
Best,
JO
Any comment on this Guys???
The scene is required and the steps to reproduce.
Locked
