Render passes not working correctly with Motion Blur
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pegot
A strange issue is occurring with the Beauty (Combined) Pass when Render Layers are used with Motion Blur.
Version: 2018.1.3 / Octane Engine 17.9
If I enable both a normal Beauty Pass and one or more of the Render Layer Passes with Motion Blur, then the Beauty Pass does not render correctly. It starts to render but is then subsequently over written by whatever layer pass is active, so that the layer pass effectively renders twice! If Motion Blur is disabled, then the Beauty Pass renders normally along with the other render passes (i.e. it is no longer overwritten by them).
This happens with either Subframe or Internal Motion Blur enabled ( Internal MB has never actually worked for me but that is an issue for another post).
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
J.C
Check the attached file out. Seems to render correctly with render passes and motion blur.
motion blur.blend
(725.33 KiB) Downloaded 179 times
System – Windows 11
Return to “Bug Reports”
