Hi Guys!
been away for a while waiting for the day I'd be able to run Octane on a proper machine... now that this has become more than a hobby for me I'm ready to pull some bucks on a dedicated machine and I'd like your advise regarding CPUs (won't be an Octane only pc...) and GPUs:
CPU: i7 2600 vs. i7 2600-k (unlocked) - I don't think I'll overclock but is it worth to get the -k just in case? difference is about 30€
GPU: GTX560 Ti vs. GTX560 (both with 2Gb) - the difference in performance is worth 30€?
thanks for any advice,
hopefully I'll be able to really join the community
cheers,
Alessandro
(another thread on) Hardware advice
- SurfingAlien
MacBookPro unibody 2x2.4GHz | 4Gb | 9400M+9600GT 256Mb | OSX 10.6.8
i7 2600-K @3.4GHz | 8Gb | GTX560Ti 2Gb | Windows7x64 | Octane 1.0 b2.52
- Jaberwocky
Try one of these
http://www.gigabyte.com/products/produc ... id=3894#ov
with a cheap AMD 6 CORE 1090T (as they are being replaced by Bulldozer very soon).
AND 8GB DDR 3 - 1600 MHZ ( 2 X 4GB DUAL CHANNEL RAM) TO START WITH
THE 560 TI - 2GB WOULD BE THE ONE TO GO FOR UNLESS YOU CAN AFFORD A GTX 580 3GB MODEL.
DON'T FORGET A GOOD POWER SUPPLY TO GO WITH IT.
SOMETHING LIKE THIS
http://www.overclockers.co.uk/showprodu ... =CA-045-BQ
THAT SHOULD GET YOU STARTED.
SOMETHING LIKE THIS
- SurfingAlien
thanks for the quick reply!
560/560Ti was a stupid question, I just noticed they have 336/384 cores so for 30€ it's a no brainer... sorry.
didn't know there was a (real) 3Gb 580... I knew of the 590 3Gb but it's 1.5 per GPU afaik. I will check my fav shop for the price (maybe I'll consider a future upgrade since I guess it will be more or less double price)
I know there are good deals with AMDs but I need to go the intel way this time... thanks anyway!
cheers,
Alessandro
EDIT: as power supply I think I'll go for a Corsair GS 800W and an ASRock P67 extreme4 MoBo (pretty cheap but should do)
cheers,
Alessandro
- SurfingAlien
update:
GTX580 3Gb -> 489€ per 512 cores | 3Gb
GTX560Ti 2Gb -> 219€ per 384 cores | 2Gb
2x GTX560Ti 2Gb -> 438€ (second card added in future) per 768 cores | 2Gb
honestly I don't care that much for the difference in performance but I wonder if I will regret not having 3Gb....? anyway, will probably go for the 560Ti and eventually switch later if needed (I can always sell the old one to lower 580 price...)
I also think I'll go for the "locked" i7-2600 (as I said I won't OC anyway)
with saved money I'll get an SSD instead
I would get 2600, SSD and EVGA GTX570 2,5GB if i were you.SurfingAlien wrote:Hi Guys!
cheers,
Alessandro
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
- Jaberwocky
Oooohhh.... missed that EVGA 570 2.5gb.....
Must check their site.... see what the damage is
- SurfingAlien
thanks for the heads-up! will check it too (they're gonna hate me!)Timmaigh wrote:I would get 2600, SSD and EVGA GTX570 2,5GB if i were you.
Maybe you should overclock that 6-core as welljamnique wrote:i7 2600-k is totally worth it. I built a system with it for a friend and after really slight overclocking it outperforms the 6-core Intel monster we have at work.
Anyway you need to get 2600k to 4,8 -4,9 GHz (seems pretty much possible on most chips) to be on par with 980x on 3,8 Ghz in Cinebench r11.5 performance-wise.
- SurfingAlien
If it was for a friend of mine, I wouldn't spend a minute wondering and overclock it to hell... LOL!jamnique wrote:i7 2600-k is totally worth it. I built a system with it for a friend and after really slight overclocking it outperforms the 6-core Intel monster we have at work.
just kidding but I really don't think I'll OC that machine because I'm using some very demanding CPU apps too and I'd like to have it with me for a few years... that said I'll maybe go for the -k anyway because of the built-in HD3000 (I'd like to try if it's possible to use it for display only while using Octane... if not I'll add a cheap nVidia like a GT430 later)
cheers,
Alessandro
