Crashes when finishing rendering, different scenes
sdanaher
Need to check I'm running the optimal versions for my setup. Everything was running smoothly since updating my system to High Sierra (thanx beppe!), but there have been cinema and plugin updates since and I'm not sure if the combination I'm running now is correct.
I've started getting familiar crashes in different scenes - unplugging a node in the shader graph while LV is running tends to cause a hard crash. But its sporadic.
Now I'm getting random crashes at the finishing stage of frames when rendering to PV. Both on high-res stills and animations. I can restart without changing anything and the render will complete. Its random.
System:
iMac 5k late 2015
OSX 10.13.6 (17G5019)
WebDriver 387.10.10.10.40.118
Cuda (newly updated, it didn't help) 418.163
eGPU with TitanX
eGPU script
Cinema R20.059
Octane Plugin V4.04 R2
Network PC w titan X and RTX 2070
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
sdanaher
Hi Beppe
Actually, I updated to 418 after the crashes had started. I was on 410.130 prior to that and was having the crashes then. I thought the latest Cuda driver might solve the problem, but it didn't. I will roll back, but the problem was under 410.
Any ideas? Webdriver? Reinstall? Revert to R19?
sdanaher wrote:Hi Beppe
Ideas will start by looking to render log output and vram/ram usages. Did you do this?
sdanaher
aoktar wrote: Ideas will start by looking to render log output and vram/ram usages. Did you do this?
no. Its crashing all the time now, but in the LV, not the PV. Here are the last two logs.
c4doctanelog.txt 3.zip
(1.28 KiB) Downloaded 132 times
c4doctanelog.txt 2.zip
(602 Bytes) Downloaded 112 times
