Global mesh setting bug (17.7)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
If Global mesh rendering setting is enabled 3d objects will have disabled smoothing.
System – Windows 11
DrawFun
Hello J.C,
Thanks for your report. It seems okay on my end. Could you please share me a simple demo to show this issue? Thanks.
DrawFun
J.C
Hi DrawFun,
here is an example file.
global mesh bug.blend
(764.03 KiB) Downloaded 210 times
System – Windows 11
ChrisH
Hi DrawFun and J.C
I tried the example file and can confirm that there's a difference between Global and Scatter (It's smooth in Scatter, but not in Global). BUT if I enable "Auto Smooth" in the mesh data settings it does appear smooth in Global as well.
Windows 10 Pro - AMD Ryzen 7 2100X 8 core 3.70GHz - 32GB RAM - GeForce GTX 1080 8GB
Octane Prime - Blender Plugin user
Metal IOR values for Octane (with .blend library): https://chris.hindefjord.se/resources/rgb-ior-metals/
Return to “Bug Reports”
