Octane - Render don't Finish or go to next frame.
cayellorena
Guys, I'm new to the community.
And I have a question/problem. Recently, I downloaded the Octane Render Demo,
to do some testing and see if my configuration supports the software, because I'm interested in buying it.
(I already use the software in my work.)
But, in my tests I saw that even if it reaches the maximum number of samples it doesn't finish rendering.
And when I finish manually the rendering time is 0:00.
And also, in an animation, it doesn't go to the next frame.
My question is...
Is it a limitation because it's a demo?
Or am I having problems?
Thanks a lot!
which version are you using?
Standalone or plugin?
And if plugin, which plugin and exact version?
Please, check the console log, you are definitely having issues, probably with CUDA drivers, or not enough VRAM for this particular scene.
ciao Beppe
