I'm trying to mix a grudge image texture with the dirt node using a Multiply node. I want to break up the Dirt nodes lines so they look more teared.
But I can't bump up the contrast on the Dirt node? I tried adding a Gradient but it doesn't do much for the contrast and I want it close to razor sharp so it will mix better with my image texture.
Is this a limitation in the Dirt node or is there a workaround? It looks to soft on the edges right now.
Here's a picture on my material setup:
Thanks in advance!
