OctaneRender™ for Blender 4.04 - 16.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • OctaneRender API will not be initialized until OctaneBlender Client is open and connects to the server
    • Generally, the initialization takes place when you open blender - so it might take a bit longer than before
  • When Blender is no longer running, deactivate the OctaneRender API so the licenses and slaves are released
    • You can turn this feature on/off at "User Preference - Addons - OctaneRender - Release Octane License After Exiting". If you use OctaneBlender on only one platform, you could turn it off.
FIXES SINCE LAST RELEASE
  • Release license when receiving interrupt signal(e.g. CTRL+C) on OSX/Linux - the release process might take several seconds. The process will exit after that.
You can read about new features of OctaneRender™ 4.04 here:
viewtopic.php?f=24&t=71375
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.5 (2.79)
Octane Server - 16.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.5 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v16.5 OSX ZIP
