OctaneRender for Maya 2018.1.2-14.34 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016.5, 2017, 2018 and 2019 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2018.1.2
Changes since version 14.32:
  • Stability improvement.
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
calus
URGENT : I still can't batch render when using Maya RenderSetup as the Octane plugin still can't find the renderable camera in the maya render layer,
this is kind of fixed with interactive render (with still an error message) but not in batch render or cmd render :(
File read in  6.3 seconds.
Warning: Octane: this scene's scale factor differs from 1.0. Octane's scene translation time can be slightly longer in this case. Consider change the scale factor to 1.0 and set the scene units to meters.
Octane: Object "topShape" is not in current layer, skipping...
Octane: Object "frontShape" is not in current layer, skipping...
Octane: Object "sideShape" is not in current layer, skipping...
Octane: Object "cameraShape3" is not in current layer, skipping...
Result: C:/PROJETS/JSUCSMDL/scenes/JSUCSMDL_avionC__6104.mb
Octane: GPUs usage:
    PRIORITY: PRIORITY_HIGH
    GeForce GTX 1070: Rendering YES, Tonemapping YES, Denoising YES, Uses priority NO
Error: Octane: Could not find renderable cameras in layer "rs_plan1"
Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/mayaBatchRenderProcedure.mel line 653: Renderer returned an error while rendering 'rs_plan1', please verify the output image.
Octane: GPUs usage:
Error: Octane: Could not find renderable cameras in layer "rs_plan2"
Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/mayaBatchRenderProcedure.mel line 653: Renderer returned an error while rendering 'rs_plan2', please verify the output image.
Octane: GPUs usage:
Error: Octane: Could not find renderable cameras in layer "rs_plan3"
Warning: file: C:/Program Files/Autodesk/Maya2019/scripts/others/mayaBatchRenderProcedure.mel line 653: Renderer returned an error while rendering 'rs_plan3', please verify the output image.
Scene C:/PROJETS/JSUCSMDL/scenes/JSUCSMDL_avionC__6104.mb completed.
Please fix the bug for batch/cmd render, I have a deadline...
Also sorry for my previous misleading report. I found batch render crashing with all scene was not because of Octane but because of a conflict with another plugin.
Pascal ANDRE
Locked
