Hey
When can we expect the C4D plugin update with vector & vertex displacement features?
I have been using the bake texture node to send mix materials into the displacement at the moment but it is quite temperamental- I have read that I should instead use the C4D layer shader and pipe that into the bake node instead?
C4D Plug-in Displacement Update
What do you mean by "quite temperamental"? Also I never advice to use C4D shaders, expecially Layer shader. A lot of crashes will wait you with that.
