OctaneRender for Maya 2018.1.2-14.31 [OBSOLETE]
Locked
Otoy® is proud to announce the availability of a new OctaneRender™ for Maya® Version 2018.1
Maya® Version Requirements
This release will work with Maya® Versions 2016.5, 2017, 2018 and 2019 64-bit on Windows, Linux and OSX operating systems.
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 419.17 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
Changelog and the installers for Octane Standalone are here:
OctaneRender Standalone 2018.1.2
Changes since version 14.30:
  • Implemented the Octane's virtual material support for randomization of Ornatrix on the each-hair level (as opposed to instance/particle level available before). Play with Random/Round-robin virtual-material types to get different randomization results.
  • Implemented the gradient UI hack to have a better UI for Octane's GPU ramp nodes.
  • Improved dynamic OSL string-attributes UI.
  • Fixed a bug: batch-render stall in some cases.
Known possible issue:
There is an Octane engine bug that may in some cases lead to crash in batch-render mode. The engine team is still investigating it...
Subscription Studio Downloads
OctaneRender for Maya Studio [Windows]
OctaneRender for Maya Studio [Linux]
OctaneRender for Maya Studio [MacOS]
Subscription Enterprise Downloads
OctaneRender for Maya Enterprise [Windows]
OctaneRender for Maya Enterprise [Linux]
OctaneRender for Maya Enterprise [MacOS]
DEMO Downloads
OctaneRender for Maya DEMO [Windows]
OctaneRender for Maya DEMO [Linux]
OctaneRender for Maya DEMO [MacOS]
calus
Maya renderLayerSetup is broken with Octane :
If the Camera is in a hierachy the plugin can't find the camera in the renderLayer and aborts rendering.
Bug_RenderLayerSetup_cameraHierachy.zip
(9.82 KiB) Downloaded 219 times
Please fix this bug, this is needed for ongoing project.
Pascal ANDRE
Locked
