I have a scene file that uses the separated motion blur vertex files generated from X-Particles Open VDB mesher for motion blur. Without these files (and thus, no motion blur on that object) Octane zips through the scene rather quickly on my 2 hybrid RTX208ti cards. However, when I enable motion blur for that object, using those vertex map tags in the appropriate slots, renderings become an order of magnitude slower, frame to frame, with each frame getting slower than the last. Without motion blur, the frame renders at about 10 seconds. With motion blur, almost 20 minutes... ouch. And, frankly, undoable, as even farm time for this would be prohibitively expensive, given my frame counts (at least until Pixel Plow comes online.)
I am using the Path Tracer set to a lowly 128 samples and rendering at a 1280 x 720 resolution. I do have an Octane Specular material on this mesh (it's supposed to be water) with noise in the bump map slot. Octane version 2018.1.2.
Is this a known issue or have I run into something new here?
X-Particles OpenVDB Motion Blur known issue?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
More information. It appears to be motion blur in general, upon further investigation.
Same results in 4.04 looks like that's just the way it is...
Don't you mind to share a scene let me test it?
I will PM you with a link. Thanks, Ahmet!
