OctaneRender™ for Blender 4.04 - 16.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links, provided on this page, are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Updated sdk to 4.04
  • Supported viewport material color("Properties-Material-Settings")
  • Supported to save material as OctaneDB("Material-Settings-Save As OctaneDB")
  • Supported camera mapped feature in Image Nodes
  • Supported to customize LocalDB path( "User Preference-Octane Render-Octane LocalDB Path")
  • Used blender temp folder("User Preference-File-Temp") to save octane temp files
  • Added "Linear space invert" for texture image nodes
  • Added "Toon shadow ambient"("Render-Octane kernel-Toon shadow ambient")
  • Added "Cast shadow" for toon lights
  • Added normal and bump for coating and sheen in universal material
  • Added simplify settings
  • Added volume properties in Material panel
  • Included alembic feature for osx/linux builds
FIXES SINCE LAST RELEASE
  • Fixed some disordered issues/crashes in LiveDB material
  • Fixed Metal/Toon/Universal material support in LiveDB material
  • Fixed unwanted reflection filter pass in exported orbx
  • Optimized material upload - now materials in inactive scenes would not be uploaded
  • Change "Octane LiveDB" in windows menu to "OctaneDB" as it contains both localDB and liveDB
You can read about new features of OctaneRender™ 4.04 here:
viewtopic.php?f=24&t=71375
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.4 (2.79)
Octane Server - 16.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
ZIP archive: Blender Octane Edition - v16.4 OSX ZIP
