Maya batch render PMC not working with EXR
p.jsi
Possible bug.
Having problems with maya batch render not starting for PMC with EXR. Same goes for PT with EXR. No Problems with TIFs.
Stuck at "Percentage of rendering done: 0 (starting)"
Octane standalone version 4.04
Octane maya plugin 4.04 -13.40
Windows 10 pro 64 bit
GTX 1080ti + 950 gtx
16 gb ddr4
Nvidia driver version 419.67 Creator ready Driver
Maya 2018
p.jsi
Seems to happening with PT with tiffs as well. This is too random. FIX please.
calus
Please share a sample scene where you can reproduce this bug,
to fix a bug the developer needs to be able to reproduce it first.
Also you may have more chance to be noticed by JimStar in the last release topic
On my side I can just ask if you use denoiser ? because this can make batch render unstable.
Pascal ANDRE
p.jsi
calus wrote:Please share a sample scene where you can reproduce this bug,
Thanks for the reply!
Yes I am using denoiser, but I have tried with denoiser turned off as well. Same problem. Copied every thing into new scene - made all new octane settings- did not work at first, but now its rendering. Hard to say when the render start, when not- its like lottery as said in other forum.
calus
Don't hesitate to join the octaneForMaya help group (you don't need to have skype installed) : https://join.skype.com/LXEQaqqfN15w
It would be easier to help you debugging scenes.
Pascal ANDRE
p.jsi
calus wrote:Don't hesitate to join the octaneForMaya help group (you don't need to have skype installed) : https://join.skype.com/LXEQaqqfN15w
Great thanks!
Return to “Autodesk Maya”
